*morphmaptotacitvecoffset
Maps nodes to surfaces along a vector.
*morphmaptotacitvecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles entity_type_elems mark_id_elems use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, a mark of elements using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the target elements along a vector, normal to the target elements, or projected normal to the elements touching the nodes.
- entity_type_nodes
- Must be set to nodes.
- mark_id_nodes
- The ID of the mark containing the nodes. Valid values are 1 and 2.
- entity_type_handles
- Must be set to handles.
- mark_id_handles
- The ID of the mark containing any following handles. Valid values are 1 and 2.
- entity_type_elems
- Must be set to elems.
- mark_id_elems
- The ID of the mark containing the elems to map to. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry (only option)
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- mode
- 0 - If *morphmaprecalc has been used to calculate new influences
- offset
- The distance to offset nodes from the target.
To map all nodes to elements 1-100 with an offset of 1.2 when not using *morphmaprecalc:
*createmark nodes 1 "all"
*createmark elems 1 1-100
*morphmaptotacitvecoffset nodes 1 handles 1 elems 1 0 1 2 1 1 1.2
# Handle error
}Version History
14.0.110
