*curveaddpoint
Adds a new point in the curve.
*curveaddpoint curve_id index xvalue yvalue
HyperMesh Tcl Modify Command
- curve_id
- The ID of the curve.
- index
- The point number (point numbering starts with 1) after which the new point needs to be added.
- xvalue
- The x coordinate of the point.
- yvalue
- The y coordinate of the point.
Examples
To add a new point with x and y values to a curve with ID curve_id having N number of points:
At the beginning:
*curveaddpoint $curve_id 0 $xvalue $yvalue After the second
point:
*curveaddpoint $curve_id 2 $xvalue $yvalue)At the end (i.e., after Nth
point):
*curveaddpoint $curve_id [hm_curve_getnumberofpoints $curve_id] $xvalue $yvalue
