*entitybundleclear
Removes all entities either from a single data item of an or from all the data items of an entitybundle.
*entitybundleclear name data_item
HyperMesh Tcl Modify Command
- name
- The name of the entity bundle to be modified.
- data_item
- The data item of the entity bundle to be cleared. Note that these indices start with 0. If set to -1, all data items are cleared.
Examples
To clear all the data stored in the first data item of the entity bundle "compbundle":
*entitybundleclear "compbundle" 0
To clear all the data stored all data items of the entity bundle
"compbundle":
*entitybundleclear "compbundle" -1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
