*dragnodestoformsurface
Drags a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher.
*dragnodestoformsurface list direction_vector distance
HyperMesh Tcl Modify Command
Drags a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a dragged surface for the automesher to use under the mesh without surface option.
- list
- The nodes to be dragged.
- direction_vector
- The direction to drag the nodes.
- distance
- The distance to drag the nodes.
*surfacemode 4
*createlist nodes 1 5 10 6 11 12 7
*createvector 1 0.0000 1.0000 0.0000
*dragnodestoformsurface 1 1 -100.0000 The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
*createlist() and *createvector() are required for this command.
If one of the surface creation modes has been set, a smooth is put through the nodes to create the surface.
