*copymarkgroup
Copies main/secondary elements from one group to another.
*copymarkgroup entity_type mark_id name
HyperMesh Tcl Modify Command
- entity_type
- Must be set to elems.
- mark_id
- The ID of the mark containing the main/secondary elements to copy. Valid values are 1 and 2.
- name
- The name of the group to copy the entities to.
Examples
To copy all elements in group1 to
group2:
*createmark elems 1 "by group name" group1
*copymarkgroup elems 1 group2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
