*nodecreateatsurfparams
Create nodes or points at parametric locations on a surface.
*nodecreateatsurfparams surf_type surf_id u1 u2 ucount v1 v2 vcount mode point_flag
HyperMesh Tcl Modify Command
This command creates nodes or points at points on given surface for given parametric values.
- surf_type
- Input surface type. Valid values are surfs or faces.
- surf_id
- Input surface ID value.
- u1
- The lower bound of U parametric range. Must be within the range 0 to 1.
- u2
- The upper bound of U parametric range. Must be within the range 0 to 1.
- ucount
- The number of nodes to create in U parametric direction. Must be ≥ 1. If the value is 1, then u1 is taken as U parametric value for created node.
- v1
- The lower bound of V parametric range. Must be within the range 0 to 1.
- v2
- The upper bound of V parametric range. Must be within the range 0 to 1.
- vcount
- The number of nodes to create in V parametric direction. Must be ≥ 1. If the value is 1, then v1 is taken as V parametric value for created node.
- mode
- Specifies whether parameters are used relative to untrimmed surface parametric area or valid parametric area is scaled to visible region. Also used to specify whether created points must reside inside visible trimmed surface area. Valid values are:
- point_flag
- Parameter specifying whether nodes or points are created. Valid values are:
To create 12 nodes (3 nodes in U, 4 nodes in V) on surface 11 between the U locations 0.5 and 0.75, and the V locations 0.1 and 0.3:
*nodecreateatsurfparams surfs 11 0.5 0.75 3 0.1 0.3 4 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
