*elementtype
Sets the global element type variable.
*elementtype config type
HyperMesh Tcl Modify Command
- config
- The configuration whose global type is set with this command. This input can be specified as config number or config string label.
- type
- The type whose global type is set with this command. This input can be specified as type number or type string label.
To set the global element type of configuration 103 to 3:
*elementtype 103 3 To set the global element type of configuration tria3 to CTRIAR in OptiStruct
profile:
*elementtype tria3 CTRIARVersion History
2022.3 - Added support for string labels as input arguments.
