*morphmapedgestosurfaceoffset
Maps selected morph volume edges to the specified surfaces.
*morphmapedgestosurfaceoffset user_mark_id entity_type mark_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command will project the handles on the marked morph volume edges to the surfaces on the mark along the specified vector, surface normal, or normal to any attached shell elements (unusual for morph volume edges).
- user_mark_id
- The ID of the user mark containing the morph edges. Valid values are 0-3.
- entity_type
- Must be set to surfs.
- mark_id
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry links
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- number_of_mid_handles
- -1 - Do not change the handles on the edges
- offset
- The distance to offset nodes from the target.
Examples
To map edges on mark 0 to a surface along a vector with offset of 1.2 and leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createmark surfs 1 1
*createvector 1 1.0 0.0 0.0
*morphmapedgestosurfaceoffset 0 surfs 1 1 1 0 1 -1 1.2
To map edges on mark 1 to a surface along the surface normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*morphmapedgestosurfaceoffset 1 surfs 1 1 1 1 1 3 0.0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.110
