*meshline_mask_class_element
Masks underlying meshline class elements.
*meshline_mask_class_element flag reserved
HyperMesh Tcl Modify Command
This command masks underlying meshline class elements.
- flag
- 0 - Turn off the underlying meshline class elements.
- reserved
- Reserved for future use. Must be set to 0.
To turn off the underlying meshline class elements:
*meshline_mask_class_element 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
