*reviewentity
Graphically reviews a specified entity.
*reviewentity entity_type search_type id_name color string_array number_of_strings
HyperMesh Tcl Modify Command
This command graphically reviews a specified entity.
- entity_type
- The type of entity to review.
- search_type
- The method used to specify the entity. The entity is specified using the id_name argument. Valid values are:
- id_name
- The ID or name of the entity, depending on search_type.
- color
- The color used to review the entity. Valid values are 1-64.
- string_array
- The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray. The valid strings are:
Examples
To review component with ID 3 using color 10:
*reviewentity comps "by id" 3 10 1 0
To review element with ID 4, along with its component, using color 10:
*createstringarray 1 showcomps
*reviewentity comps "by id" 3 10 1 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.130
