*mechexportdaf
Exports the dummy angle file for the current dummy.
*mechexportdaf filename
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
- filename
- The full name and path of the file to export.
To export the current dummy DAF file as C:/temp/dummy.daf:
*mechexportdaf "C:/temp/dummy.daf"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
