*absorbmember
Absorbs existing 1D elements or lines to skeleton entities.
*absorbmember entity_type break_angle=<value> create_legs=<value> ?mark=<mark_id>? ?prefix=<value>?
HyperMesh Tcl Modify Command
Absorbs selected entities (1D elements or lines) to create members and memberjoints (from connecting nodes or points). If 1D elements are absorbed and they have a beamsection assigned to them, a membersection containing the beamsection is created and assigned to the member. No cleaning operation is performed at the end of the absorption.
- entity_type
- The entity type to absorb. Valid values are elements and lines.
- along_line=<value>
- The flag to create control locations of member on the line selected.
- auto_detect_thin_solids=<value>
- The flag to detect thin solids for the realized beam section of the member section. This flag works only if the intersectingentitytype dataname is set to solids (55).
- autoweld=<value>
- The flag to perform auto weld on the realized beam section of the member section.
- break_angle=<value>
- The break angle limit (in degrees) to define if two continuous members may be merged into a single member.
- create_legs=<value>
- The flag defining if legs should be created on memberjoints. Valid values are 0 and 1.
- create_member_sections=<value>
- The flag to create member sections on memberjoints and members created during the process.
- create_sketch=<value>
- The flag to create sketch entity on beam section when member section is realized. Only supported for section type "real".
- elemconfig=<value>
- The element config of the 1D elements of member joint mesh. For example, bar2, rod.
- elemdensity=<value>
- The element density to be used for meshing the member joint leg.
- elemsize=<value>
- The size of the 1D elements to be created during meshing if elemdensity is not specified.
- elemtype=<value>
- The element type of the 1D element of member joint mesh. For example, CBAR, CBEAM, CROD.
- mark=<mark_id>
- The ID of the mark containing the entities to absorb. Valid values are 1 and 2.
- planelength=<value>
- The length of the member section plane.
- planewidth=<value>
- The width of the member section plane.
- prefix=<value>
- The prefix for the member name.
- realize=<value>
- The flag to realize member joints, members and member sections created during the process.
- sectiontype=<value>
- The section type string for beam section. Valid values are:
- useelemdensity=<value>
- The flag determines if element density is to be used for meshing the member joint. Valid values:
- vertex_angle=<value>
- Section contour is smoothened if vertex angle between two lines is below this limit. Valid values are between 0 to 90.0.
Examples
To absorb displayed lines:
*createmark lines 1 displayed
*absorbmember lines mark=1 create_legs=1 break_angle=10
To absorb elements ID 1-100 with a name prefix "top_":
*createmark elements 1 1-100
*absorbmember elements mark=1 create_legs=0 break_angle=10 prefix="top_"
Absorbing a mark of lines to create sections:
*createmark lines 1 3
*absorbmember lines mark=1 create_legs=0 create_member_sections=1 numcontrollocs=3 realize=1 autoweld=1 auto_detect_thin_solids=1 create_sketch=0 along_line=1 intersectingentitytype=2 planelength=300 planewidth=300 vertexangle=60 break_angle=1 elemconfig=bar2 elemtype=CBEAM elemsize=40.000000 sectiontype=real
# Handle error
}Version History
2022
2023 - Added new options along_line, auto_detect_thin_solids, autoweld, create_member_sections, create_sketch, elemconfig, elemdensity , elemsize, elemtype, planelength, planewidth, realize, sectiontype, useelemdensity, and vertex_angle.
