*morphshapecreatelist
Creates a number of new shapes from the morph list.
*morphshapecreatelist name option color
HyperMesh Tcl Modify Command
This command creates a number of new shapes from the morph list.
- name
- The base name of the shape.
- option
- The shape's save options. Valid values are:
- 0 - Save as handle and node perturbations.
- 1 - Save as pure node perturbations.
- color
- The color of of the shapes. Valid values are 1 through 64.
To create shapes with the base name "shape" for all morphs on the morph
list:
*morphshapecreatelist "shape" 1 33Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
