*hwct_addrepsfromlibrary
Adds representations from a connected library.
*hwct_addrepsfromlibrary entity_type mark_id rep_alias_list params
HyperMesh Tcl Modify Command
- entity_type
- The type of connected library. Supported for parts and subsystems.
- mark_id
- The ID of the mark of entities. Valid values are 1 and 2.
- rep_alias_list
- The list of representation alias names to load.
- params
- A quoted, comma separated string, containing additional optional name=value
parameters. Valid parameters are:
- load=<value>
- 0 - Do not load the rep alias for the subsystem
- overwrite=<value>
- 0 - Do not overwrite the session information
- repfolder=<value>
- The folder in which the representation exists.
Examples
Load a crash representation for subsystem 2 from C:/temp/subsystems:
*createmark subsystems 1 2
*hwct_addrepsfromlibrary subsystems 1 crash "overwrite=1, repfolder=c:/temp/subsystems"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
2024 - Added parts to supported entity types.
