*barelementupdatewithoffsets
Updates the vector, pin flags, property, direction node and offset for multiple bar and/or bar3 elements.
*barelementupdatewithoffsets mark_id update_vector vector_option vector_id update_pins pin_flags_a pin_flags_b update_property property_name update_orientation orientation_node y_dir update_offset_a offset_system_a offset_x_a offset_y_a offset_z_a update_offset_b offset_system_b offset_x_b offset_y_b offset_z_b
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the bar and/or bar3 elements to update. Valid values are 1 and 2.
- update_vector
- If non-zero, vector_id is used to update the local y-axis.
- vector_option
- 0 - Vector is defined by using global coordinate system.
- vector_id
- The ID of the y-axis vector to use, defined using the *createvector command. If used, this must be set to 1.
- update_pins
- If non-zero, pin_flags_a and pin_flags_b are used to update the pin flags.
- pin_flags_a
- The pin flags at end a. A pin flag of 0 passes forces in all degrees of freedom.
- pin_flags_b
- The pin flags at end b. A pin flag of 0 passes force in all degrees of freedom.
- update_property
- If non-zero, property_name is used to update the property.
- property_name
- The name of the property collector assigned to the bar.
- update_orientation
- If non-zero, the direction node will be updated.
- orientation_node
- The orientation node ID. y_dir specifies whether this node defines the local y- or local z-axis.
- y_dir
- If set to 1, then orientation_node defines the local y-axis of the bar. Otherwise, orientation_node defines the local z-axis.
- update_offset_a
- If non-zero, the offsets at end a are updated.
- update_offset_b
- If non-zero, the offsets at end b are updated.
- offset_system_a
- The system used to define the offsets at end a. Valid values are:
- 0 - Offsets given in global coordinate system.
- 1 - Offsets given in local coordinate system of node1.
- 2 - Offsets given in elemental coordinate system.
- offset_x_a
- The offset in the x-direction at end a.
- offset_y_a
- The offset in the y-direction at end a.
- offset_z_a
- The offset in the z-direction at end a.
- offset_system_b
- The system used to define the offsets at end b. Valid values are:
- offset_x_b
- The offset in the x-direction at end b.
- offset_y_b
- The offset in the y-direction at end b.
- offset_z_b
- The offset in the z-direction at end b.
Examples
To update the elements on mark 1 with y-axis defined by vector (0.0, 1.0, and
0.0):
*createvector 1 0.0000 1.0000 0.0000
*barelementupdatewithoffsets 1 1 0 1 0 0 0 0 "" 0 0 0 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0To update the elements on mark with y-axis oriented in global XY
plane:
*barelementupdatewithoffsets 1 1 2 1 0 0 0 0 "" 0 0 0 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0To update the elements on mark 1 with orientation node 3 in
y-direction:
*barelementupdatewithoffsets 1 0 0 1 0 0 0 0 "" 1 3 1 0 0 0.0 0.0 0.0 0 0 0.0 0.0 0.0To update the elements on mark 1 with offsets a defined in global system having offset
vector (0.2, 0.2, and 0.2) and offsets b defined in global system having offset vector (0.3,
0.3, and
0.3):
*barelementupdatewithoffsets 1 0 0 1 0 0 0 0 "" 0 0 0 1 0 0 0.2 0.2 0.2 1 0 0.3 0.3 0.3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
