*realizefieldloads
Realizes engineering loads into classical loads or groups.
*realizefieldloads mark_id ?skip_delete?
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of engineering loads to realize into classical loads or groups. Valid values are 1 and 2.
- skip_delete
- 0 - Delete all engineering loads after realization (default)
Examples
Realize all engineering force
loads:
*createmark loads 1 "by config" 1
*realizefieldloads 1Realize all engineering loads and skip
deletion:
*createmark loads 1 all
*realizefieldloads 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
2022.2 - Added support for groups.
