*readmeshcontroltemplate
Imports a Mesh Control template file.
*readmeshcontroltemplate filename
HyperMesh Tcl Modify Command
Imports a Mesh Control template file. This is an XML formatted file. This contains all of the mesh control information, except for the entity selection. A file coming from SimLab can also be read.
- filename
- The full name and path of the file to import.
To import the file C:/temp/meshcontrol.xml:
*readcontroltemplate C:/temp/meshcontrol.xml
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
