*entitydisplaywithattached
Isolates an entity and its attached entities.
*entitydisplaywithattached entity_type mark_id attached_entity_type display_flag
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to be used for display. Currently only valid for groups.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- attached_entity_type
- Valid values are comps, elems and groups.
- display_flag
- 0 - Show
Examples
To show the components attached to group 1:
*createmark group 1 1
*entitydisplaywithattached group 1 comps 0
To isolate the components attached to groups 1 and
10:
*createmark group 1 1 10
*entitydisplaywithattached group 1 comps 1To show the elements attached to group
1:
*entitydisplaywithattached group 1 elems 0To isolate the elements attached to groups 1 and
10:
*entitydisplaywithattached group 1 elems 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
