*solverconvert
Converts a model from one solver to another.
*solverconvert source_solver destination_solver source_type destination_type batch ?config_file_path?
HyperMesh Tcl Modify Command
This command converts a model from one solver to another.
Supported solvers are:
| Solver Name | Solver ID | Solver Type |
| Nastran | 1 | |
| OptiStruct | 1 | |
| Abaqus | 2 | Standard2D, Standard3D, Explicit |
| ANSYS | 8 | |
| LS-DYNA | 9 | Keyword971_R12.0, Keyword971_R11.2, Keyword971_R10.1, Keyword971_R9.3,Keyword971_R8.0, Keyword971_R7.1, Keyword971_R6.1, Keyword971, Keyword970 |
| PAM-CRASH | 18 | Pamcrash2G2020, Pamcrash2G2019, Pamcrash2G2018, Pamcrash2G2017, Pamcrash2G2016, Pamcrash2G2015, Pamcrash2G2014, Pamcrash2G2013, Pamcrash2G2012, Pamcrash2G2011, Pamcrash2G2010, Pamcrash2G2008, Pamcrash2G2007, Pamcrash2G2006, Pamcrash2G2005, Pamcrash2G2004 |
| Radioss | 20 | Radioss2022, Radioss2021, Radioss2020, Radioss2019, Radioss2018, Radioss2017, Block140, Block130, Block120, Block110, Block100, Block90, Block51, Block44 |
| Permas | 21 | Permas |
| ADVC | 30 | advc |
Supported conversions are:
| Source Solver Name | Destination Solver Name |
| Abaqus | Nastran |
| Abaqus | OptiStruct |
| ANSYS | Nastran |
| ANSYS | OptiStruct |
| LS-DYNA | Nastran |
| LS-DYNA | OptiStruct |
| Radioss | PAM-CRASH |
| PAM-CRASH | Radioss |
| Nastran | Abaqus |
| OptiStruct | Abaqus |
| Nastran | ANSYS |
| OptiStruct | ANSYS |
| Nastran | LS-DYNA |
| Nastran | Radioss |
| OptiStruct | Radioss |
| ANSYS | Abaqus |
| Nastran | OptiStruct |
| Abaqus | Radioss |
| ADVC | OptiStruct |
| LS-DYNA | PAM-CRASH |
| LS-DYNA | Radioss |
| Nastran | PAM-CRASH |
| PAM-CRASH | LS-DYNA |
| PAM-CRASH | Nastran |
| Permas | OptiStruct |
| Radioss | OptiStruct |
- source_solver
- The source solver name or ID.
- destination_solver
- The destination solver name or ID.
- source_type
- The source solver template type.
- destination_type
- The destination solver template type.
- batch
- Flag that indicates if the conversion should be run in batch mode.
- 0 - No batch mode
- 1 - Batch mode for Solver Conversion
- 2 - Batch mode for Unified Conversion
- ?config_file_path?
- The full path for the configuration file containing the entity mapping details, to be used for the conversion. This is useful when the user has restrictions on modifying the file in the installation. When the configuration file path is not specified or the path is not valid, the conversion will use the default configuration file from the installation.
Examples
Convert Abaqus Standard3D model to OptiStruct in batch
mode:
*solverconvert Abaqus OptiStruct Standard3D "" 1or
*solverconvert 2 1 Standard3D "" 1Convert Radioss Block90 model to PAM-CRASH Pamcrash2G2007 without batch
mode:
*solverconvert RadiossBlock Pamcrash Block90 Pamcrash2G2007 0or
*solverconvert 20 18 Block90 Pamcrash2G2007 0Convert Abaqus Standard3D model to RadiossBlock Radioss2021 in Unified
Conversion:
*solverconvert "Abaqus" "RadiossBlock" "Standard3D" "Radioss2021" "2" ""or
*solverconvert 2 20 "Standard3D" "Radioss2021" "2" ""Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
2017.1 - Added a new optional argument config_file_path. Updated list of supported solver versions.
