*fill_fe_gaps_lines
Fills gaps in FE from lines selected on both sides of the gap.
*fill_fe_gaps_lines mark_id1 mark_id2 max_width string_array number_of_strings
HyperMesh Tcl Modify Command
- mark_id1
- The mark ID containing the lines at the first boundary. Valid values are 1 and 2.
- mark_id2
- The mark ID containing the lines at the second boundary. Valid values are 1 and 2.
- max_width
- Maximum allowed gap width to be filled.
- string_array
- The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To fill gaps less than 100 between lists 1 and 2, including remeshing:
*createmark lines 1 1 2 3 4 5
*createmark lines 2 6 7 8 9 10
*createstringarray 2 "Remesh: 1" "DefineMaxWidth: 1"
*fill_fe_gaps_lines 1 2 100.0 1 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
