*collectormarkmove
Moves and/or sorts the entities on a mark.
*collectormarkmove entity_type mark_id move_to_front sort
HyperMesh Tcl Modify Command
This command moves and/or sorts the entities on a mark. This affects their order within the browser and the advanced entity selection menus.
- entity_type
- The type of entity to move. Valid values can be found from the organize panel.
- mark_id
- The ID of the mark containing the entities to move. Valid values are 1 and 2.
- move_to_front
- A flag that indicates if the selected entities should be moved to the front of the
list. Valid values are:
- 0 - Move the marked entities to the end of the list.
- 1 - Move the marked entities to the front of the list.
- sort
- A flag that indicates how the entities will be sorted. Valid values are:
- 0 - The marked entities are not to be sorted.
- 1 - The marked entities are sorted by name.
- 2 - The marked entities are sorted by ID.
Examples
To move the displayed components to the top of the list with no
sorting:
*createmark comps 1 displayed
*collectormarkmove comps 1 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
