*hf_setdiesymmetry
Sets the symmetry plane for the die module.
*hf_setdiesymmetry normal_x normal_y normal_z origin_x origin_y origin_z shape_flag node_1 node_2
HyperMesh Tcl Modify Command
This command sets the symmetry plane for the die module.
- normal_x
- x-coordinate of the plane normal.
- normal_y
- y-coordinate of the plane normal.
- normal_z
- z-coordinate of the plane normal.
- origin_x
- x-coordinate of the plane origin.
- origin_y
- y-coordinate of the plane origin.
- origin_z
- z-coordinate of the plane origin.
- shape_flag
- A flag that identifies the following cases:
- node_1
- First node ID that identifies the portion of the part that is used by the double attached part feature.
- node_2
- Second node ID that identifies the portion of the part that is used by the double attached part feature.
To set the symmetry plane z=0 for the die module:
*hf_setdiesymmetry 0. 0. 1. 0. 0. 0. 0 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
