*barelementcreatewithoffsets
Creates a bar element with offsets.
*barelementcreatewithoffsets node1 node2 vector_id orientation_node y_dir pin_flags_a pin_flags_b property_name offset_system_a offset_x_a offset y_a offset_z_a offset_system_b offset_x_b offset_y_b offset_z_b
HyperMesh Tcl Modify Command
- node1
- The first node ID (end a).
- node2
- The second node ID (end b).
- vector_id
- The ID of the y-axis vector to use, defined using the *createvector command. If used, this must be set to 1. This argument is only used if orientation_node is 0.
- orientation_node
- The orientation node ID. If set to 0, then vector_id is used. If non-zero, then y_dir specifies whether this node defines the local y- or local z-axis.
- y_dir
- If set to 1, then orientation_node defines the local y-axis of the bar. Otherwise, orientation_node defines the local z-axis.
- pin_flags_a
- The pin flags at end a. A pin flag of 0 passes forces in all degrees of freedom.
- pin_flags_b
- The pin flags at end b. A pin flag of 0 passes force in all degrees of freedom.
- property_name
- The name of the property collector assigned to the bar.
- offset_system_a
- The system used to define the offsets at end a. Valid values are:
- 0 - Offsets given in global coordinate system.
- 1 - Offsets given in local coordinate system of node1.
- 2 - Offsets given in elemental coordinate system.
- offset_x_a
- The offset in the x-direction at end a.
- offset_y_a
- The offset in the y-direction at end a.
- offset_z_a
- The offset in the z-direction at end a.
- offset_system_b
- The system used to define the offsets at end b. Valid values are:
- offset_x_b
- The offset in the x-direction at end b.
- offset_y_b
- The offset in the y-direction at end b.
- offset_z_b
- The offset in the z-direction at end b.
Examples
To create a bar3 element between nodes 101, 102 and 103 with its local y-axis defined by
the vector (1, 0, and 0) and assigned property prop1. The element has an offset vector at
end a defined using the global system (0.2, 0.2, and 0.2) and offset vector at end b defined
using the global system (0.3, 0.3, and
0.3):
*createvector 1 1.0000 0.0000 0.0000
*bar3elementcreatewithoffsets 101 102 103 1 0 0 0 0 "prop1" 0 0.2 0.2 0.2 0 0.3 0.3 0.3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
