*hideview
Hides the entities with respect to a view saved using *saveviewmask.
*hideview name entity_type_id
HyperMesh Tcl Modify Command
- name
- The name of the view to hide.
- entity_type_id
- The entity type ID to hide.
Examples
Hide the components (entity type ID 3) in view
View2:
*hideview View2 3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
