*readqiviewsettings
Loads a file containing the element quality view mode settings.
*readqiviewsettings file
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It loads settings from a text file created by *writeqiviewsettings, and resets the current settings used in this view mode.
- flag
- The full name and path of the file to load containing the QI view settings.
To load the current settings from the file C:/settings/qiview.txt:
*readqiviewsettings "C:/settings/qiview.txt"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
