*CE_ConnectorTrimAdvanced
Trim/split the spot/seam connectors using nodes.
*CE_ConnectorTrimAdvanced style mark_id node_mark_id tolerance snap mode1 mode2
HyperMesh Tcl Modify Command
This command is used to trim/split the spot/seam connectors using nodes.
- style
- The style of connectors to edit. Valid values are area, seam and spot.
- mark_id
- The ID of the mark of connectors. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark of nodes. Valid values are 1 and 2.
- tolerance
- The tolerance value used to snap the nodes to the point of spot connectors when snap is 1.
- snap
- 0 - Do not snap nodes to spot connectors
- mode1
- 0 - Split
- mode2
- 0 - None
Examples
To split spot connector 101 using node
1001:
*createmark connectors 1 101
*createmark nodes 1 1001
*CE_ConnectorTrimAdvanced spot 1 1 0.5 1 0 0To trim seam connector 102 using node
1002:
*createmark connectors 1 102
*createmark nodes 1 1002
*CE_ConnectorTrimAdvanced seam 1 1 0.5 1 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
