*ExportAssemblyAndGlobalEntities
Exports part assembly and child data.
*ExportAssemblyAndGlobalEntities file_path
HyperMesh Tcl Modify Command
- file_path
- The location to write to.
Examples
To export to
C:/temp:
*ExportAssemblyAndGlobalEntities "C:/temp"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
