*linereverse
Reverse line direction.
*linereverse line_id
HyperMesh Tcl Modify Command
This command reverses the direction for a given input line. Works for free lines only.
- line_id
- Input line ID.
To reverse line 12:
*linereverse 12
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
