*gap_sealing
Creates patches to close the gap between components.
*gap_sealing entity_type mark_id $ctrl db_id
HyperMesh Tcl Modify Command
- entity_type
- The type of input entity. Valid values are elems and comps.
- mark_id
- The ID of the mark containing the input entities.
- controls
- The string defining the command parameters.
- database
- The flag defining which database is used as the input.
Examples
To create patches such that the selected input does not leak with leak size equal to 5.0
and the seed being a point indicating the “inside” of the input:
*createmark comps 1 displayed
set ctrl {"leakSize":5.0, "maxsize":0.0, "seed": 4000.0 0.0 1500.0, "target": ()}
*gap_sealing comps 1 ${ctrl} 2To create patches to close the gap between components within distance of
10.0:
set ctrl {"proximity":10.0}
*gap_sealing comps 1 ${ctrl} 2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
