*surfacemarksplitwithelemedges
Trims the selected surfaces by specified FE/element edges.
*surfacemarksplitwithelemedges surf_mark=<mark_id> "edge_list=<value>"
HyperMesh Tcl Modify Command
Trims the input CAD and/or FE surfaces by selected list of element edges.
- surf_mark=<mark_id>
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- edge_list=<value>
- The list of element edges represented by start and end node IDs of each edge.
Examples
To trim the surface ID 3425 by the list of element edges defined by node ID pairs
1098-1096, 1034-1100, 1034-1035, and 1100-1098:
*createmark surfaces 1 3425
*surfacemarksplitwithelemedges surf_mark=1 "edge_list=1098-1096 1034-1100 1034-1035 1100-1098"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.1
