*surfacemarkremoveallpinholes
Removes all pinholes of a specified size from the specified surfaces.
*surfacemarkremoveallpinholes mark diameter
HyperMesh Tcl Modify Command
- mark
- The mark ID containing the surfaces.
- diameter
- The upper-limit of the pinhole’s diameter.
To remove all pinholes of all surfaces using a radius of
5.
*createmark surfs 1 all
*surfacemarkremoveallpinholes 1 5.0 The *createmark() command is required.
