*alignnode3
Aligns multiple nodes along the imaginary line between two other nodes.
*alignnode3 end_node1 end_node2 mark_id
HyperMesh Tcl Modify Command
- end_node1
- The ID of the first end node.
- end_node2
- The ID of the second end node.
- mark_id
- The ID of the mark of nodes to align. Valid values are 1 and 2.
Examples
To align nodes 100-110 between nodes 200 and 300:
*createmark nodes 1 100-110
*alignnode2 200 300 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
