*sethistoryrecord
Sets whether history recording is enabled or disabled.
*sethistoryrecord state
HyperMesh Tcl Modify Command
- state
- 0 - Disables all history recording, including potential legacy use cases
- 1 - Enables history recording
To disable all history recording:
*sethistoryrecord 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
