*aic_setoption
Sets current project directory, classifier, or label.
*aic_setoption option value
HyperMesh Tcl Modify Command
Sets project directory, classifier, or label based on the specified option.
- option
- Valid values are ProjectDirectory, CurrentClassifier, and CurrentLabel.
- value
- Name of the project directory, classifier, or label to be set.
Examples
To set the project
directory:
*aic_setoption ProjectDirectory D:/Temp/project_ATo set the current
classifier:
*aic_setoption CurrentClassifier ShapeAICarTo set the current
label:
*aic_setoption CurrentLabel DoorAssemblyErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
