*modelcheck_applycorrection
Runs auto correction on a given check, if checks are run.
*modelcheck_applycorrection check_display_name correction_display_name
HyperMesh Tcl Modify Command
longDescription
- check_display_name
- The GUI display name of the check. This is case sensitive.
- correction_display_name
- The GUI name of the correction. This is case sensitive.
Examples
To run the "Delete unused materials" auto correction for "Unused materials":
*modelcheck_applycorrectionon "Unused materials" "Delete unused materials"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
