*surfacesplitwithplane
Splits a surface with an infinite plane.
*surfacesplitwithplane surface plane
HyperMesh Tcl Modify Command
- surface
- The surface to be split.
- plane
- The plane used to split the surface.
To split surface 1 with the xy plane (normal equals the z-axis):
*createplane 2 0.0 0.0 1.0 0.0 0.0 0.0
*surfacesplitwithplane 1 2 Errors
None.
