*aic_createnew
Creates a new classifier or label for classification process.
*aic_createnew option value
HyperMesh Tcl Modify Command
- option
- Valid values are:
- value
- Name of the new classifier or the new label.
Examples
To create ShapeAICar folder in project
directory:
*aic_createnew Classifier ShapeAICarTo create a new
label:
*aic_createnew Label DoorAssemblyErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
