*CE_GlobalSetDouble
Set global double parameters relating to the display of connectors.
*CE_GlobalSetDouble name value
HyperMesh Tcl Modify Command
This command sets global double parameters to control the display of connectors.
- name
- The name of the parameter to set:
- g_ce_size
- Determines the display size of connectors.
- value
- The double value to set for the name parameter.
Examples
To set the global connector display size to
2.0:
*CE_GlobalSetDouble g_ce_size 2.0Version History
9.0
