*metadatamarkstringarray
Creates string array metadata on the specified mark of entities.
*metadatamarkstringarray entity_type mark_id name string_array number_of_strings
HyperMesh Tcl Modify Command
- entity_type
- The type of entities contained on the mark.
- mark_id
- The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
- name
- The name by which the metadata will be referenced.
- string_array
- The ID of the string array that contains the values. The array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the array created using *createsrtingarray.
To add metadata named String_Vals with the values "Warped" and "Elements" to elements
1-100:
*createmark elems 1 1-100
*createstringarray 2 "Warped" "Elements"
*metadatamarkstringarray elems 1 "String_Vals" 1 2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
