*hex_refinement
Refines selected hexa elements while maintaining connectivity.
*hex_refinement entity_type1 mark_id1 entity_type2 mark_id2 refinement_level
HyperMesh Tcl Modify Command
- entity_type1
- The type of entity. Currently supported for elements.
- mark_id1
- The ID of the mark containing hexa elements to be refined. Valid values are 1 and 2.
- entity_type2
- mark_id2
- The ID of the mark containing all the elements attached to elements in mark mark_id1. Valid values are 1 and 2.
- refinement_level
- The level of refinement. Level 1 will refine the hexa elements by splitting them to 1/3 of their original size.
To refine the displayed hexa elements to level 1:
*createmark elements 1 "displayed"
*createmark elements 2 "all"
*hex_refinement elems 1 elems 2 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.1
